Ошибка чата
Ошибка чата
Что это за ошибка?
(14.24 КБ) 93 скачивания
@serg@
Re: Ошибка чата
Сообщение @serg@ »
у меня таковая обычно вызывается при не корректном поведении плагина (обычно если лезит не в свою память)
Re: Ошибка чата
И вот еще ошибки откуда то!
[color=#FF0000][24.09.2010 15:02:06] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:07] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:09] Application error: "Access violation at address 7492574A in module 'comctl32.dll'. Read of address 00000042"
[24.09.2010 15:02:09] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:11] Application error: "Access violation at address 74924434 in module 'comctl32.dll'. Read of address 00000042"
[24.09.2010 15:02:11] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:12] Module 60 (1) is activated
[24.09.2010 15:02:12] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:22] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:28] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:28] Module 60 (11) is activated
[24.09.2010 15:02:29] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:37] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:37] Module 60 (11) is activated
[24.09.2010 15:02:38] Application error: "Access violation at address 7613E3E7 in module 'MSCTF.dll'. Read of address 0000011C"
[24.09.2010 15:02:40] Application error: "Stack overflow"[/color]
@serg@
Re: Ошибка чата
Сообщение @serg@ »
конечно разработчики более точно ответят, но попробуй 2 вещи:
*переустановить клиента чата
*отключить плагины
Кстати какие плагины установлены?
Re: Ошибка чата
Bots
Crazy
Мафия!
Больше нету плагинов!
@serg@
Re: Ошибка чата
Сообщение @serg@ »
если ошибка часто бывает просто поочерёдно можно попробовать по отключать плагины, но сначала переустанови клиент на всякий случай. Ошибка либо в dll, либо кто-то (какой-то плагин) не туда залез.
Re: Ошибка чата
[24.09.2010 17:20:08] Произошло отключение от сервера
[24.09.2010 17:20:45] Связь с сервером нарушена (10054 - 5). Ожидание восстановления связи...
Re: Ошибка чата
@serg@ писал(а):Ошибка либо в dll, либо кто-то (какой-то плагин) не туда залез.
Совершенно верно.
sasha писал(а):[24.09.2010 17:20:08] Произошло отключение от сервера
Это стандартное сообщение выводимое при разрыве связи с сервером.
